[Qgis-user] Shape file points not appearing in 2.0.1
Zirneklitis
eko at lanet.lv
Thu Nov 21 04:46:40 PST 2013
I could not find any disappearing point using 2.1.0-Master.
Karlis
Eureka Modélisation wrote:
> I follow this thread with interest because I have a layer with exactly
> the same behaviour, behaviour which also appear in the transition from
> QGIS 1.8 to 2.0.
> Unfortunately, I don't find any point with all NULL attributes in this
> layer.
> You can find the layer here : https://db.tt/1kPuqEvd (a bit big, sory !)
>>>>>> Am 19.11.2013 19:02, schrieb Daniel Kranich:
>>>>>>> I have a shape file that is a point layer which has been working
>>>>>>> fine
>>>>>>> and displaying fine in 1.8. When I open the layer in 2.0.1, The
>>>>>>> symbols
>>>>>>> no longer appear on the map. The attribute table still has all
>>>>>>> the data,
>>>>>>> and If I select one and pan the map to that selection, It zooms
>>>>>>> in to
>>>>>>> where that particular point should be but the point is not
>>>>>>> visible on
>>>>>>> the map.
