[Qgis-user] Shape file points not appearing in 2.0.1
Werner Macho
werner.macho at gmail.com
Thu Nov 21 05:12:59 PST 2013
Hi!
Provided shapefile loads without any problems and is being displayed nicely
(if we can say nicely for a grid of points) :)
kind regards
Werner
On Thu, Nov 21, 2013 at 2:46 PM, Zirneklitis <eko at lanet.lv> wrote:
> Hi,
> I could not find any disappearing point using 2.1.0-Master.
> Karlis
> Eureka Modélisation wrote:
>> I follow this thread with interest because I have a layer with exactly
>> the same behaviour, behaviour which also appear in the transition from
>> QGIS 1.8 to 2.0.
>> Unfortunately, I don't find any point with all NULL attributes in this
>> layer.
>> You can find the layer here : https://db.tt/1kPuqEvd (a bit big, sory !)
>>>>>>> Am 19.11.2013 19:02, schrieb Daniel Kranich:
>>>>>>>> I have a shape file that is a point layer which has been working
>>>>>>>> fine
>>>>>>>> and displaying fine in 1.8. When I open the layer in 2.0.1, The
>>>>>>>> symbols
>>>>>>>> no longer appear on the map. The attribute table still has all
>>>>>>>> the data,
>>>>>>>> and If I select one and pan the map to that selection, It zooms
>>>>>>>> in to
>>>>>>>> where that particular point should be but the point is not
>>>>>>>> visible on
>>>>>>>> the map.
> Qgis-user mailing list
