[Qgis-user] Shape file points not appearing in 2.0.1
    Eureka Modélisation
    ismael.bernard at eureka-model.com
    Thu Nov 21 06:47:27 PST 2013
Thank you for these tests !
I really don't understand what happen...
It may be a problem specific to my configuration. I load back the file
from the link I provide and the problem is still here for me in QGIS
2.0.1. Here is what I see when I zoom in my layer :
1: all points still there
2: only a part of the point in one side appear
3: no more points
You can see it in the screen capture here : https://db.tt/1nnAKDht
Ismaël
On 21/11/2013 14:12, Werner Macho wrote:
> Hi!
> Provided shapefile loads without any problems and is being displayed nicely
> (if we can say nicely for a grid of points) :)
> kind regards
> Werner
> On Thu, Nov 21, 2013 at 2:46 PM, Zirneklitis <eko at lanet.lv> wrote:
>> Hi,
>> I could not find any disappearing point using 2.1.0-Master.
>> Karlis
>> Eureka Modélisation wrote:
>>> I follow this thread with interest because I have a layer with exactly
>>> the same behaviour, behaviour which also appear in the transition from
>>> QGIS 1.8 to 2.0.
>>> Unfortunately, I don't find any point with all NULL attributes in this
>>> layer.
>>> You can find the layer here : https://db.tt/1kPuqEvd (a bit big, sory !)
>>>>>>>> Am 19.11.2013 19:02, schrieb Daniel Kranich:
>>>>>>>>> I have a shape file that is a point layer which has been working
>>>>>>>>> fine
>>>>>>>>> and displaying fine in 1.8. When I open the layer in 2.0.1, The
>>>>>>>>> symbols
>>>>>>>>> no longer appear on the map. The attribute table still has all
>>>>>>>>> the data,
>>>>>>>>> and If I select one and pan the map to that selection, It zooms
>>>>>>>>> in to
>>>>>>>>> where that particular point should be but the point is not
>>>>>>>>> visible on
>>>>>>>>> the map.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
