[Qgis-user] MrSID raster and QGIS in linux
Eric Goddard
egoddard1010 at gmail.com
Sun Nov 24 08:45:15 PST 2013
It isn't strictly true that you're crap out of luck--you just have to
download the mrsid API and register it with ldconfig. Depending on
your system, sometimes there are gdal plugins that you can then
install. This is how it is setup on Debian based systems. If there
isn't a plugin available, then you have to compile gdal with MrSid
support. Because MrSid is proprietary, gdal can't be distributed with
support built in. I wrote a guide for some friends for compiling the
GIS stack with MrSid/ECW support, but it is for ubuntu-based systems.
I'm posting the link here, perhaps it will help in getting it set up
in Fedora. Most of the actual compilation instructions should work,
but the dependencies and paths will be different.
https://docs.google.com/document/d/1TjWU_9gnUkayVAky3GGanPaQT-t453HLcWrITZX5Zrc/edit?usp=sharing
Eric
On Sun, Nov 24, 2013 at 10:16 AM, Randal Hale
<rjhale at northrivergeographic.com> wrote:
> There isn't - Mr Sid and ECW are proprietary image formats. If you are on a
> windows machine they get a separate library/file/gdal type plugin and if you
> are on a linux machine your just crap outta luck. I've actually been playing
> around with building sid support into gdal (which is another long story).
> The best you can do is to decompress the image using the Sid decoder
> (downloaded from Lizardtech). Just hope you don't have an overly compressed
> sid image that blows up to 160GB on decompression.
> The next best thing we could do is figure out some way to get this back into
> linux. If I had the coding chops I would do it...since I'm diving into
> fantasy currently I would also date Jennifer Lawrence.
> Randy
> Randal Hale, GISP
> North River Geographic Systems, Inc
> http://www.northrivergeographic.com
> 423.653.3611 rjhale at northrivergeographic.com
> <mailto:rjhale at northrivergeographic.com>
> twitter:rjhale
> http://about.me/rjhale
> On 11/24/2013 11:05 AM, john polo wrote:
>> Hello,
>> I am using Fedora 19 on a 32 bit machine. I had installed QGIS 1.8 and the
>> GDAL packages, but was not able to use .sid rasters from the geospatial
>> gateway that the feds run. I was getting an error message saying that it was
>> not a supported raster source when I tried to load the file. Is there
>> perhaps an additional package that's not obvious to a newb that would help
>> with support for MrSID in Fedora?
>> john
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
