[Qgis-user] Issues using Points in polygon with PostGIS layer
Richard Duivenvoorde
rdmailings at duif.net
Sun Nov 24 13:17:16 PST 2013
On 24-11-13 21:30, Lee Hachadoorian wrote:
> I was using `Vector → Analysis Tools → Points in polygon` to count
> events in a hexgrid (created with MMQGIS). The point data came from a
> PostGIS layer. The layer has a query restriction and the filtered data
> set has ~230k points. When I run it, it just crashes (sometimes
> immediately, sometimes after several seconds). When I export the PostGIS
> layer to shapefile and run it, it works (although it takes ~2 hours to
> run).
> Are there issues with using this feature with PostGIS layers? Is it the
> size of the dataset?
Hi Lee,
I did some some testing here, with a (small) postgis dataset. No
problems here.
The vector analysis tools are written in Python, and I think it has been
asked before to redo at least some of them in cpp to make these faster.
Especially those that are often used with larger datasets...
(Google Summer of Code project?)
I think in these cases the best way to test this is:
- try it with the latest/testing version on different computers
(preferably different OS's too)
- if still a problem: create an issue, AND provide the test data
somewhere (so others can test and confirm this issue)
- depending on your tools: maybe run qgis via strace and append the
output to the issue
As you can see here:
https://github.com/qgis/QGIS/blob/master/python/plugins/fTools/tools/doPointsInPolygon.py#L180
the plugin apparently creates an index with (in your case) all 230K
points in it.
Later, the features are fetched one by one to test if they intersect
(#206). I would think that could be done easier/faster(??) nowadays by
using the inGeom.boundingBox
Well as said: plz create an issue and provide some test data, maybe
other people interested in this can try things out this too...
Regards,
