[Qgis-user] including images in (database) attributes
    Brent Wood
    pcreso at pcreso.com
    Mon Nov 25 14:10:09 PST 2013
Cheers Niklaas,
The website is developed using the Silverstripe CMS, rainer at silverstripe.com is the guy behind the web mapping stuff. The images are retrieved using a custom web service, from a local image database (now with several 100,000 images). Commercial application called Atlas (www.atlamd.com).
We funded the development of a map search for images in Atlas, which we are looking to update at present. See the map searchtool at
https://atlas.niwa.co.nz/public.jsp
Enable Assets - images (right of map)
update the map (button top right of map)
(don't zoom right now - the back end web map server is broken)
Choose the left hand Marquee selection tool (box)
draw a box around some area with images on the map
the images in that box will be displayed...
 (note that I've just added about 16,000 echogram images - they are being processed, with thumbnails, etc being generated in a low priority background job - so you'll see lots of entries with no thumbnails until that completes)
This also seems to be very similar to the sort of facility you are looking at implementing - images associated with features (or locations) on a map which can be previewed & downloaded.
I'm considering developing a QGIS plugin to provide similar access from a map based desktop - part of this initiative: http://www.niwa.co.nz/software/quantum-map
Brent
 From: Niklaas Baudet von Gersdorff <niklaas at kulturflatrate.net>
To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
Sent: Tuesday, November 26, 2013 10:10 AM
Subject: Re: [Qgis-user] including images in (database) attributes
Hi Brent,
Brent Wood [2013-11-25 12:38 -0800] :
>Not quite sure how this fits your needs, but the QGIS "actions" facility was
>implemented originally to do just this on the desktop - and it works well.
OK, great I'll have a look at it!
>Also, we did not use QGIS for this, but built an (Open Source) web
>facility to
>do this, with a set of images at each location:
>[1]http://www.os2020.org.nz/project-map/
>Click a green triangle (DTIS location) to drill down to the images at each
>site...
This looks great! I could at least digg in the code and get some ideas.
>May give you some ideas if nothing else....
Definitely! Thank you,
Niklaas
http://www.kulturflatrate.net/niklaas
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131125/dcd09c3d/attachment.html>
