[Qgis-user] How to generate a topo map from an excel file
Alexandre Neto
senhor.neto at gmail.com
Tue Nov 26 02:22:58 PST 2013
Hello Eyal,
You need to convert your excel into a Comma Separate Values (CSV) file. You
can do it in Excel itself using "save as..."
After that, you can use the "Layer > Add Delimited Text Layer" to add your
file in the map as points.
Best regards,
Alexandre Neto
On Tue, Nov 26, 2013 at 10:16 AM, Eyal Saiet <ejsaiet at alaska.edu> wrote:
> Hello all,
> I have an excel file that looks like a 2D array ( Lat and Long on the
> axis). I would like to convert this file to a topo map using QGIS.
> First, I would like to add that Excel sheet, but is too large so it will
> not go through the server e-mail-list. Second, I would appreciate any
> solutions to the merit of the problem.
> Suggestions?
> Eyal Saiet
> University of Alaska Fairbanks
> Fairbanks, AK 99775
> (907) 750 6555 (cell)
> ejsaiet at alaska.edu <Gregory.Walker at gi.alaska.edu>
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131126/b21eac29/attachment.html>
