[Qgis-user] Counting the sum of points in a polygon
Andreas Neumann
a.neumann at carto.net
Wed Nov 27 07:14:29 PST 2013
Hi Steve,
Oops - I was wrong. The "Zonal Statistics" plugin only works between a
vector and a raster layer and aggregates (sum/mean/max) the raster cell
values intersected with a polygon vector layer.
This is different from your needs.
For point in polygon there is a "Point in Polygon" function which at
least counts the points aggregated by polygon. Output is a shapefile.
Does that suit your needs or do you need more than just the count?
Sorry, no sum/min/max/mean - just simple counts.
If you have your data in Postgis, it would be very easy to do aggregates
based on the polygon geometry. I could provide a SQL query if you are
interested.
Andreas
Am 27.11.2013 15:57, schrieb Steven Campbell:
> Hi Andreas
> Is this the same as the basic statistics tool that you can find in the Vector tools? I can see the plugin is already loaded but cannot see any Zonal Stats button/option anywhere. I'm using the latest weekly build at the minute.
> Thanks
> Steve
> Qgis-user mailing list
