[Qgis-user] [Qgis-developer] Shortcut changes in QGIS; call for opinions
Nathan Woodrow
madmanwoo at gmail.com
Thu Nov 28 14:19:34 PST 2013
Given that adding/removing a complex layer can be expensive and there is no
undo I would suggest to have a single key shortcut (D) with confirm and a
modified one without (Ctrl-D). You want to avoid the user doing something
dangerous and in this case that is removing a layer layer without undo.
- Nathan
On Fri, Nov 29, 2013 at 3:11 AM, Borys Jurgiel <lists at borysjurgiel.pl>wrote:
> Dnia czwartek, 28 listopada 2013 15:11:30 A Huarte pisze:
> > + Remove layer from legend -> Ctrl+D with ask for confirmation.
> > Now QGIS does not ask for confirmation.
> What about leaving the possibibility to remove the layer without
> confirmation
> with a separate shortcut?
> Actually the first what I do after a fresh install is changing "Ctrl-D" to
> simple "D", as I couldn't imagine myself using two fingers for such basic
> action like layer removing ;)) The same with a dozen of other Ctrl-*
> shortcuts. And I believe I'm not the only one.
> Regards,
> B.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131129/487436bb/attachment.html>
