[Qgis-user] [Qgis-developer] Shortcut changes in QGIS; call for opinions
Borys Jurgiel
lists at borysjurgiel.pl
Thu Nov 28 15:55:22 PST 2013
Please don't understand me wrong - I don't insist to use single-key shortcuts
by default. We had them in early versions and we decided to drop them, so it
wouldn't make much sense to mess with them again. Personally I miss them, but
It's no problem for me to change them.
I only refered to the singe-key shortcut in order to underline the importance
of this action and protest against removing the non-confirmation option
completely ;) IMHO, it would be a painful regression. But it's no problem for
me if it's not connected to any key by default.
Dnia piÄ…tek, 29 listopada 2013 08:19:34 Nathan Woodrow pisze:
> Given that adding/removing a complex layer can be expensive and there is no
> undo I would suggest to have a single key shortcut (D) with confirm and a
> modified one without (Ctrl-D). You want to avoid the user doing something
> dangerous and in this case that is removing a layer layer without undo.
> - Nathan
> On Fri, Nov 29, 2013 at 3:11 AM, Borys Jurgiel <lists at borysjurgiel.pl>wrote:
> > Dnia czwartek, 28 listopada 2013 15:11:30 A Huarte pisze:
> > > + Remove layer from legend -> Ctrl+D with ask for confirmation.
> > > Now QGIS does not ask for confirmation.
> > What about leaving the possibibility to remove the layer without
> > confirmation
> > with a separate shortcut?
> > Actually the first what I do after a fresh install is changing "Ctrl-D" to
> > simple "D", as I couldn't imagine myself using two fingers for such basic
> > action like layer removing ;)) The same with a dozen of other Ctrl-*
> > shortcuts. And I believe I'm not the only one.
> > Regards,
> > B.
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
