[Qgis-user] [Qgis-developer] Shortcut changes in QGIS; call for opinions
Andreas Neumann a.neumann at carto.net
Fri Nov 29 01:18:26 PST 2013
Hi all,
I would prefer to have only one shortcut - not a parallel "d" and
"ctrl-d" with different behavious. This sounds confusing to me.
As long as we don't have an undo option I would like to have the
confirmation question always when removing one or more layers. It is not
something that people do all the time, so it wouldn't be annoying. I
also accidentally removed layers with right-click and there was no
confirmation that stopped me. So I would prefer to have the confirmation
when removing layers in all cases.
Andreas
Am 29.11.2013 07:56, schrieb Richard Duivenvoorde:
> On 28-11-13 23:19, Nathan Woodrow wrote:
>> Given that adding/removing a complex layer can be expensive and there is
>> no undo I would suggest to have a single key shortcut (D) with confirm
>> and a modified one without (Ctrl-D).  You want to avoid the user doing
>> something dangerous and in this case that is removing a layer layer
>> without undo.
> Personally I do not like to add more then one key for the same action,
> keep stuff simple.
> Although we could make confirmation an option, the number of options in
> the options dialogs are also growing and growing. I've already a lot of
> options to tweak for a new user to make it the best way for him/her.
> If we do a a first time dialog with a 'do not ask me anymore', that is
> nice, BUT it means that we have to put a way to undo that somewhere in a
> dialog/option too (while the logic code actually is easy: just an extra
> if/flag).
> Let's keep the interface as simple/logical/friendly as possible
> especially for non power users.
> Could we maybe create some poweruser options list (like gnome-settings
> or :config in firefox). In which we put this kind of flags?
> So no cluttering of the interface with 'do not ask' actions or more
> options in the options dialogs. But only a list of configs which you
> could use.
> Which in practice would actually be a Qtable with filter for QSettings
> of QGIS, in my case: ~/.config/QGIS/QGIS2.conf
> Regards,
> ps Borys: we should not be afraid of some regression if it makes QGIS
> better in general :-)
> Qgis-user mailing list
