[Qgis-user] Mapinfo and qgis file's datum problem
nagellette
necipenesgengec at gmail.com
Fri Nov 29 06:48:39 PST 2013
his post has NOT been accepted by the mailing list yet.
Hi All,
I am new at Qgis and I enjoyed and find it usefuşş for most parts. I am
currently using map info for some buffer analysis and had some problems
about trying to do same analysis in qgis.
I am trying to put a ring buffer for 100m. I converted 100m into degrees
since my default projection in qgis is wgs84 epsg:4326. I putted a point got
a ring in qgis.
Ring created in qgis
<http://osgeo-org.1560.x6.nabble.com/file/n5091891/ring_qgis.jpg>
I tried to do the same in mapinfo. created the ring for same point.
Ring created in mapinfo
<http://osgeo-org.1560.x6.nabble.com/file/n5091891/ring_mapinfo.jpg>
problem starts here: when I open the buffer file that I created qgis in
mapinfo the ring in qgis distorted along vertical direction, and when I open
the buffer file that I created in mapinfo in qgis the ring in mapinfo
distorted along horizontal direction.
Comparing rings in qgis
<http://osgeo-org.1560.x6.nabble.com/file/n5091891/ring_comparison_qgis.jpg>
Comparing rings in mapinfo
<http://osgeo-org.1560.x6.nabble.com/file/n5091891/ring_comparison_mapinfo.jpg>
I am pretty sure that all referrence systems both in mapinfo and qgis is set
to wgs84 epsg:4326.
How can I solve this?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapinfo-and-qgis-file-s-datum-problem-tp5091891.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
