[Qgis-user] WMTS in QGIS
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Tue Oct 1 03:02:38 PDT 2013
Hi Lene,
Slightly delayed reply. It may be worth reporting this as a bug on the QGIS
tracker - http://hub.qgis.org/ . It seems there are some issues from having
integrated WMS and WTMS into the same dialog.
Regards,
Jonathan
On 10 September 2013 06:38, Lene Fischer <lfi at life.ku.dk> wrote:
> Hello Bernd
> I have inserted my username and password - but get the same - no result.
> But when I read the errorstatement from QGIS I can see the following:
> http://kortforsyningen.kms.dk/orto_foraar?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&
> It says WMS not WMTS and GetMap not GetTile
> It seems to be the wrong request for getting a tile. Is there perhaps a
> method to force QGIS to ask for a Tileservice insted of WMS ?
> Regards
> Lene Fischer
> ________________________________________
> Fra: qgis-user-bounces at lists.osgeo.org [qgis-user-bounces at lists.osgeo.org]
> på vegne af Bernd Vogelgesang [bernd.vogelgesang at gmx.de]
> Sendt: 10. september 2013 01:39
> Til: qgis-user at lists.osgeo.org
> Emne: Re: [Qgis-user] WMTS in QGIS
> Hi Lene,
> in the protokol (bottom-right corner), i can read this after loading
> Kartenabfrage-Fehler (Status: 200; Antwort:<?xml version="1.0"
> encoding="UTF-8"?>
> <ServiceExceptionReport version="1.1.0">
> <ServiceException>User not authenticated: Please create your account at
> download.kortforsyningen.dk.</ServiceException>
> </ServiceExceptionReport>
> ; Content-Type: ; URL:
> http://kortforsyningen.kms.dk/orto_foraar?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&BBOX=62741.96757465013070032,5873940.79319193959236145,1073502.98025026079267263,6513338.45932245720177889&SRS=EPSG:25832&WIDTH=818&HEIGHT=519&LAYERS=orto_foraar&STYLES=&FORMAT=image/jpeg&DPI=96&MAP_RESOLUTION=96&FORMAT_OPTIONS=dpi:96
> Am 10.09.2013, 01:01 Uhr, schrieb Lene Fischer <lfi at life.ku.dk>:
> So, I think there is a login missing, or wrong. You didn't mention neither.
> Greetz
> Bernd
> > Hi
> > I´m trying to use WMTS in QGIS 1.9
> > I have the following url
> http://kortforsyningen.kms.dk/service?request=GetCapabilities&acceptversions=1.0.0&ticket=f74e5c53feb8e96c245ae5326b76167e&servicename=orto_foraar&service=WMTS
> > I connect and see the list of maps to choose
> > Click Add
> > and the layer is shown layer, but not shown in the mapview.
> > Can anyone explain what I do wrong
> > Regards
> > Lene Fischer
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> Bernd Vogelgesang * Siedlerstrasse 2 * 91083 Baiersdorf * +49-9133-825374
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131001/2f06aeb4/attachment.html>
