[Qgis-user] WMTS in QGIS
Lene Fischer
lfi at life.ku.dk
Tue Oct 1 08:31:00 PDT 2013
Hi Jonathan,
I´ve already done that
Bug #8595
Regards
Lene Fischer
Fra: Jonathan Moules [jonathanmoules at warwickshire.gov.uk]
Sendt: 1. oktober 2013 12:02
Til: Lene Fischer
Cc: Bernd Vogelgesang; qgis-user at lists.osgeo.org
Emne: Re: [Qgis-user] WMTS in QGIS
Hi Lene,
Slightly delayed reply. It may be worth reporting this as a bug on the QGIS tracker - http://hub.qgis.org/ . It seems there are some issues from having integrated WMS and WTMS into the same dialog.
Regards,
Jonathan
On 10 September 2013 06:38, Lene Fischer <lfi at life.ku.dk<mailto:lfi at life.ku.dk>> wrote:
Hello Bernd
I have inserted my username and password - but get the same - no result.
But when I read the errorstatement from QGIS I can see the following:
http://kortforsyningen.kms.dk/orto_foraar?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&
It says WMS not WMTS and GetMap not GetTile
It seems to be the wrong request for getting a tile. Is there perhaps a method to force QGIS to ask for a Tileservice insted of WMS ?
Regards
Lene Fischer
________________________________________
Fra: qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org> [qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>] på vegne af Bernd Vogelgesang [bernd.vogelgesang at gmx.de<mailto:bernd.vogelgesang at gmx.de>]
Sendt: 10. september 2013 01:39
Til: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Hi Lene,
in the protokol (bottom-right corner), i can read this after loading
Kartenabfrage-Fehler (Status: 200; Antwort:<?xml version="1.0"
encoding="UTF-8"?>
<ServiceExceptionReport version="1.1.0">
<ServiceException>User not authenticated: Please create your account at
download.kortforsyningen.dk<http://download.kortforsyningen.dk>.</ServiceException>
</ServiceExceptionReport>
; Content-Type: ; URL:
http://kortforsyningen.kms.dk/orto_foraar?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&BBOX=62741.96757465013070032,5873940.79319193959236145,1073502.98025026079267263,6513338.45932245720177889&SRS=EPSG:25832&WIDTH=818&HEIGHT=519&LAYERS=orto_foraar&STYLES=&FORMAT=image/jpeg&DPI=96&MAP_RESOLUTION=96&FORMAT_OPTIONS=dpi:96)
Am 10.09.2013, 01:01 Uhr, schrieb Lene Fischer <lfi at life.ku.dk<mailto:lfi at life.ku.dk>>:
So, I think there is a login missing, or wrong. You didn't mention neither.
Greetz
Bernd
> Hi
> I´m trying to use WMTS in QGIS 1.9
> I have the following url
> http://kortforsyningen.kms.dk/service?request=GetCapabilities&acceptversions=1.0.0&ticket=f74e5c53feb8e96c245ae5326b76167e&servicename=orto_foraar&service=WMTS
> I connect and see the list of maps to choose
> Click Add
> and the layer is shown layer, but not shown in the mapview.
> Can anyone explain what I do wrong
> Regards
> Lene Fischer
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
Bernd Vogelgesang * Siedlerstrasse 2 * 91083 Baiersdorf * +49-9133-825374<tel:%2B49-9133-825374>
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131001/ffeb0ac1/attachment.html>
