[Qgis-user] install qgis 2.0.1-2 win7 64
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Tue Oct 1 03:06:27 PDT 2013
They both worked fine for me when I tried them. Might it be a permissions
issue? Also did you change where it went?
Cheers,
Jonathan
On 1 October 2013 10:57, <j.allain at agglo-paysflers.fr> wrote:
> Hello,
> I've downloaded qgis2.0.1 standalone installer for winx86 and x86_64. Both
> programs finishes correctly but each times, the "QGIS DUFOUR" repository is
> not created and nothing is installed. Has anybody met this behaviour ?
> Thanks
> Jonathan A
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131001/83fa8c0e/attachment.html>
