[Qgis-user] install qgis 2.0.1-2 win7 64
Kalle Kronholm
kalle at kronholm.cc
Tue Oct 1 03:15:20 PDT 2013
Hi
I had similar issues with the standalone QGIS 64 bits installer. But after
running the OSgeo4W installer for 64 bits, I now have QGIS running.
Kalle
2013/10/1 Jonathan Moules <jonathanmoules at warwickshire.gov.uk>
> Hi,
> They both worked fine for me when I tried them. Might it be a permissions
> issue? Also did you change where it went?
> Cheers,
> Jonathan
> On 1 October 2013 10:57, <j.allain at agglo-paysflers.fr> wrote:
>> Hello,
>> I've downloaded qgis2.0.1 standalone installer for winx86 and x86_64.
>> Both programs finishes correctly but each times, the "QGIS DUFOUR"
>> repository is not created and nothing is installed. Has anybody met this
>> behaviour ?
>> Thanks
>> Jonathan A
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131001/0f8f4a57/attachment.html>
