[Qgis-user] Field calculator rounded to integer
Carlos Cerdán
sig.upagu at gmail.com
Tue Oct 1 08:28:17 PDT 2013
Hi list, developers specially
I have an issue with a points layer: It has a real-double field with 6
decimals that can't calculate decimals, just integers.
For example in Field Calculator, I try to actualize the field "buf_grados"
with field "buff_metros"/111120 [1] to estimate a distance in meters to
degrees, but result is just integer (0.000000). If you divide per another
minor number (eg 10), result is not zero, but just integer.
I've tried with a new field, but result is same: just integer
I've tried closing and reopening the project, and even restarting my PC,
but nothing.
It's a bug?
Carlos
Ubuntu 12.04 - QGIS 2.0.1
[1] Layer can be dowloaded from:
https://docs.google.com/file/d/0B7OCKS4ZyCTAR2JZQVYwYXg3WlU/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131001/246af2f9/attachment.html>
