[Qgis-user] Field calculator rounded to integer
Andre Joost
andre+joost at nurfuerspam.de
Tue Oct 1 09:39:42 PDT 2013
Am 01.10.2013 17:28, schrieb Carlos Cerdán:
> Hi list, developers specially
> I have an issue with a points layer: It has a real-double field with 6
> decimals that can't calculate decimals, just integers.
> For example in Field Calculator, I try to actualize the field "buf_grados"
> with field "buff_metros"/111120 [1] to estimate a distance in meters to
> degrees, but result is just integer (0.000000). If you divide per another
> minor number (eg 10), result is not zero, but just integer.
> It's a bug?
For me, it works with QGIS 1.8.0 and 2.0.1.
However, the buff_metros field is integer.So I used:
toreal( "buff_metros" ) / 111120.0
to have a division of real values.
Greetings,
André Joost
