[Qgis-user] Prossesing>Saga>Catchment area
Lene Fischer
lfi at life.ku.dk
Wed Oct 2 01:58:30 PDT 2013
Problem solved.....
In Processing>Option I forgot to remove "Enable SAGA 2.0.8 compability"
Sorry for making noise!
Kind regards
Lene Fischer
Fra: qgis-user-bounces at lists.osgeo.org [qgis-user-bounces at lists.osgeo.org] på vegne af Lene Fischer [lfi at life.ku.dk]
Sendt: 2. oktober 2013 10:42
Til: qgis-user at lists.osgeo.org
Emne: Re: [Qgis-user] Prossesing>Saga>Catchment area
Hi again,
Now I have tried to run teh algorithm again, but without opening the layer when finish.
No error - but when I try to open the rasterfile an errormessage says:
Raster layer: C:/Users/Lene Fischer/Desktop/cacthmentarea.tif is not a supported raster data source
(d:\src\qgis-2.0.1\src\app\qgisapp.cpp : 8614 : QgisApp::addRasterLayers)
I open the xml file and it look like this:
<PAMDataset>
<GeoTransform> 6.8147680000000005e+005, 1.6000000000000001e+000, 0.0000000000000000e+000, 6.2095407999999998e+006, 0.0000000000000000e+000,-1.6000000000000001e+000</GeoTransform>
<PAMRasterBand band="1">
<NoDataValue>-9.99990000000000E+004</NoDataValue>
<Metadata>
<MDI key="STATISTICS_MAXIMUM">11993.599609375</MDI>
<MDI key="STATISTICS_MEAN">26.276661153761</MDI>
<MDI key="STATISTICS_MINIMUM">2.5599999427795</MDI>
<MDI key="STATISTICS_STDDEV">112.99805366138</MDI>
</Metadata>
</PAMRasterBand>
</PAMDataset>
It is impossible to open the TIF file.
Someone who can help in this matter.
Kind regard
Lene Fischer
Sendt: 1. oktober 2013 17:44
Emne: [Qgis-user] Prossesing>Saga>Catchment area
Hello,
Using QGIS 2.0 trying to make a Cacthment area (recursive) with Saga module.
Loading DEM with pixelsize 1.6 m
Save file >Open output only for Catchemnt area.
Result: Errormessage and a note telling that SAGA is installed correct (brilliant note!!)
But I don´t know how to read the log.
I made a video http://screencast.com/t/FBSqTg2J0sI
Any suggestion to solve this problem.
Regards
Lene Fischer
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131002/ca12679e/attachment.html>
