[Qgis-user] QGIS 2 broken (by me?) on Ubuntu 13.04
Zoltan Szecsei zoltans at geograph.co.za
Thu Oct 3 00:04:32 PDT 2013
Hi Guys,
I had this and GRASS and OTB, Monteverdi etc etc installed and all
running happily, but now I must have updated something and QGis is broken.
I cannot 100% say that QGis was still running after I added monteverdi
1.16.0 (otb 3.18.1) because I added monteverdi as an afterthought. OTB
was working nicely through QGis Sextante.
root at gl00:/home/zls# apt-get install qgis
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
  qgis : Depends: libgdal1 (>= 1.8.0) but it is not going to be installed
         Depends: qgis-providers (= 2.0.1-2+raring1) but it is not going
to be installed
         Recommends: qgis-plugin-grass but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Any help resolving this without breaking OTB would be appreciated.
Thanks & regards,
Zoltan
