[Qgis-user] Processing/GRASS: question on v.surf.rst
    Andreas Neumann
    a.neumann at carto.net
    Thu Oct  3 01:34:12 PDT 2013
 This is more a question towards GRASS/Processing specialists.
 There are two versions for interpolation with regularized splines with
 tension. There is:
 v.surf.rst and v.surf.rst.cvdev
 What is the reason for the two different versions and what is the
 difference?
 Both seem to accept only point layers, whereas I know that v.surf.rst
 should accept linestring/contourline data if the contours are simplified
 with the dmin (minimum distance) parameter. v.surf.rst.cvdev does not
 seem to output all the raster surfaces like "surface", "aspect",
 "slope", "curvature", etc.
 So could the v.surf.rst interface in Processing be changed that it also
 accepts linestring data as input?
 Thanks,
 Andreas
