[Qgis-user] There isn't entry in geometry_columns!
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Thu Oct 3 06:51:03 PDT 2013
I think this was meant to be sent to the entire list rather than just me.
On 3 October 2013 14:49, . <digitalmaps at cox.net> wrote:
> Of course. This is a warning message found on a table info page in DB
> Manager for a PostGIS table. Along with the error message, instead of the
> proper icon showing the geometry type in the tree listing of DB Manager
> there is a question mark icon. This happened so long ago I can't remember
> the exact sequence which led up to the appearance of the message.
> I had created the table and entered data with the wrong CRS. In an effort
> to correct this error, I exported the data to a SHP file then re-imported
> it. I just don't remember exactly what the sequence was. Anyway, at the end
> of the procedure I had the data back in my table with the desired CRS.
> Everything worked normally. I use the table daily without problem. Sometime
> later I noticed the warning message. I've just now gotten around to finding
> the source of the error message.
> I've searched Google and perused my copy of PosgGIS in Action but I lack
> advanced programming skills.
> On 10/3/2013 6:02 AM, Jonathan Moules wrote:
> I think you're going to have to be a lot more descriptive. Without
> information about the problem it's unlikely anyone will be able to help.
> On 1 October 2013 20:55, . <digitalmaps at cox.net> wrote:
>> Any way to fix this problem easily?
>> Stay Frosty!
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
> Stay Frosty!
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131003/cdea720f/attachment.html>
