[Qgis-user] There isn't entry in geometry_columns!
digitalmaps at cox.net
Thu Oct 3 08:05:42 PDT 2013
On 10/3/2013 8:51 AM, Jonathan Moules wrote:
> I think this was meant to be sent to the entire list rather than just me.
> On 3 October 2013 14:49, . <digitalmaps at cox.net
> <mailto:digitalmaps at cox.net>> wrote:
> Of course. This is a warning message found on a table info page in
> DB Manager for a PostGIS table. Along with the error message,
> instead of the proper icon showing the geometry type in the tree
> listing of DB Manager there is a question mark icon. This happened
> so long ago I can't remember the exact sequence which led up to
> the appearance of the message.
> I had created the table and entered data with the wrong CRS. In an
> effort to correct this error, I exported the data to a SHP file
> then re-imported it. I just don't remember exactly what the
> sequence was. Anyway, at the end of the procedure I had the data
> back in my table with the desired CRS. Everything worked normally.
> I use the table daily without problem. Sometime later I noticed
> the warning message. I've just now gotten around to finding the
> source of the error message.
> I've searched Google and perused my copy of PosgGIS in Action but
> I lack advanced programming skills.
> On 10/3/2013 6:02 AM, Jonathan Moules wrote:
>> I think you're going to have to be a lot more descriptive.
>> Without information about the problem it's unlikely anyone will
>> be able to help.
>> On 1 October 2013 20:55, . <digitalmaps at cox.net
>> Any way to fix this problem easily?
>> Stay Frosty!
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> This transmission is intended for the named addressee(s) only and
>> may contain sensitive or protectively marked material up to
>> RESTRICTED and should be handled accordingly. Unless you are the
>> named addressee (or authorised to receive it for the addressee)
>> you may not copy or use it, or disclose it to anyone else. If you
>> have received this transmission in error please notify the sender
>> immediately. All email traffic sent to or from us, including
>> without limitation all GCSX traffic, may be subject to recording
>> and/or monitoring in accordance with relevant legislation.
> Stay Frosty!
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use
> it, or disclose it to anyone else. If you have received this
> transmission in error please notify the sender immediately. All email
> traffic sent to or from us, including without limitation all GCSX
> traffic, may be subject to recording and/or monitoring in accordance
Oops, I just woke up when I replied.
Stay Frosty!
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131003/dbfc0809/attachment.html>
