[Qgis-user] Projects created with version 1.8 not displayed	with 2.0
    Jonathan Moules
    jonathanmoules at warwickshire.gov.uk
    Fri Oct  4 06:38:35 PDT 2013
Hi Francesco,
  Sounds like a bug (regression) to me. I'd suggest opening a bug report (
http://hub.qgis.org/projects/quantum-gis/ ) and ideally attached some of
the malfunctioning workspaces.
 Hopefully someone else on the list has some actually useful suggestions on
how to work around it. ;-)
Cheers,
Jonathan
On 4 October 2013 12:04, Francesco Vidotto <francesco.vidotto at unito.it>wrote:
> Dear all,
> I apologize for having already posted this issue in Italian. I did not
> realize that the list was in English.
> I have some projects that were created with version 1.8 that are not
> displayed with 2.0. The files seem to be opened correctly and no warning
> (nor error) messages are displayed. Though, no layers are displayed in the
> map legend and no maps are visible on the map view area. It seems that only
> the SR and the extension are somewhat opened, as the coordinates displayed
> in the status bar seem to be reasonable.
> The problem occurs with some projects only, but I cannot tell you what
> traits they have in common. As I have deleted version 1.8 to install 2.0, I
> cannot check with the previous version if they share a same "corrupt" layer.
> I use Qgis 2.0 on a Mac with MacOSX 10.6.8.
> Many thanks
> Francesco
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131004/679d351e/attachment.html>
