[Qgis-user] Polygon coloring
    KLGan
    1klgan at gmail.com
    Sat Oct  5 05:38:23 PDT 2013
Hi Jonathan,
Thank you for the information and the links.
Cheers :-)
KLGan
On 4 October 2013 20:02, Jonathan Moules <jonathanmoules at warwickshire.gov.uk
> wrote:
> If you google around ("qgis manual download pdf") there are several PDF
> documents. I doubt any are for 2.0, but for basic stuff QGIS hasn't changed
> too much between versions. I.e.:
> http://manual.linfiniti.com/
> http://nathanw.net/2013/01/06/qgis-manuals/
> etc.
> Jonathan
> On 3 October 2013 11:27, KLGan <1klgan at gmail.com> wrote:
>> Thanks Andreas,
>> I am new to QGIS, and for a moment thought this is not possible. Glad to
>> know these are basic stuffs in gis :-)
>> Will browse the manual (how I wish the manual is available for download)
>> Thanks
>> KLGan
>> On 3 October 2013 17:54, Andreas Neumann <a.neumann at carto.net> wrote:
>>> Hi,
>>> This is very basic GIS stuff. Please consult the QGIS manual for this.
>>> As a hint:
>>> You need to define either of:
>>> * a rule
>>> * a category
>>> * assign a column that contains color values
>>> These are available in the layer properties and in the "Styles" tab.
>>> All of these are described in the QGIS manual:
>>> http://www.qgis.org/en/docs/user_manual/working_with_vector/vector_properties.html#style-menu
>>> Good luck,
>>> Andreas
>>> Am 03.10.2013 09:44, schrieb KLGan:
>>> > Hi,
>>> > I have a layer with many polygons. I want to change the color of some
>>> of
>>> > the polygons. How can I do this in QGIS?
>>> > Currently changes apply to all the polygons, not individual one.
>>> > Thanks :-)
>>> > KLGan
>>> > _______________________________________________
>>> > Qgis-user mailing list
>>> > Qgis-user at lists.osgeo.org
>>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131005/8c7b5c98/attachment.html>
