[Qgis-user] QGIS 2.0.1
Andreas Neumann a.neumann at carto.net
Tue Oct 8 07:59:48 PDT 2013
Hi Lucien,
Oh - I was falsely assuming you are on Windows. On Windows it is easy to
install QGIS 1.8 and 2.0 in parallel, by using the OSGeo4W installer. I
don't know about Linux if you do not compile from source.
If you compile from source it is easy as you can define the
CMAKE_INSTALL_PREFIX and you can write a small batch start-script to
start the other version. Something like:
export LD_LIBRARY_PATH=/path/to/your/qgis/install/lib
/path/to/your/qgis/install/bin/qgis
Maybe other users know how to install already compiled versions in
parallel. My guess is that you would have to install the qgis libs in
separate folders and set the LD_LIBRARY_PATH
Andreas
Am 08.10.2013 14:36, schrieb BLANDENIER Lucien:
> Thank you andrea for your answer!
> You convinced me! Just one additional question. On Linux, if I upgrade to qgis2, is to possible to go back to 1.8? And how? I have some projects and maps I don't want to upgrade. I've looked on internet how to go back to a previous version but I didn't found something.
> Lucien
> ps : thank you to all the developers who are working on this project !!!
> ________________________________________
> De : qgis-user-bounces at lists.osgeo.org [qgis-user-bounces at lists.osgeo.org] de la part de Andreas Neumann [a.neumann at carto.net]
> Envoyé : mardi 8 octobre 2013 16:22
> À : qgis-user at lists.osgeo.org
> Objet : Re: [Qgis-user] QGIS 2.0.1
> Hi Lucien,
> You should definitely use the 2.0x releases. It is in most respects
> better than the 1.x releases.
> Here is a list of most of the new features:
> http://changelog.linfiniti.com/version/1/ (don't be fooled about the
> URL, it really describes the new features of version 2)
> - Especially the new Processing toolbox and graphical modeler is new and
> exciting.
> If you are on Windows, you should definitely go with the 64bit version,
> which is new as well.
> As with all new features there are also bugs. If you rely on external
> software like GRASS and SAGA there may still be some integration issues
> we are working on. There will be updated installers that should fix
> these issues.
> As to compatibility: it mostly is, but there are some issues when going
> from old to new symbology and from old to new labeling.
> Andreas
> Am 08.10.2013 14:05, schrieb BLANDENIER Lucien:
>> Dear all,
>> I've seen that the QGIS 2.0.1 is now available and looks promising! Did someone already has some feedback ? Is it stable?
>> I saw that the map manager changed, as well as other features. Is it compatible with previous versions?
>> Regards
>> Lucien
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
