[Qgis-user] QGIS 2.0.1
Werner Macho werner.macho at gmail.com
Tue Oct 8 10:21:31 PDT 2013
Hi!
there is a short section about having two different versions side by
side if you compile it by yourself ..
http://quantumofgis.blogspot.co.uk/2013/04/help-in-helping-qgis-becoming-better.html
maybe that helps you a bit ..
regards
Werner
On Tue, Oct 8, 2013 at 4:59 PM, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi Lucien,
> Oh - I was falsely assuming you are on Windows. On Windows it is easy to
> install QGIS 1.8 and 2.0 in parallel, by using the OSGeo4W installer. I
> don't know about Linux if you do not compile from source.
> If you compile from source it is easy as you can define the
> CMAKE_INSTALL_PREFIX and you can write a small batch start-script to
> start the other version. Something like:
> export LD_LIBRARY_PATH=/path/to/your/qgis/install/lib
> /path/to/your/qgis/install/bin/qgis
> Maybe other users know how to install already compiled versions in
> parallel. My guess is that you would have to install the qgis libs in
> separate folders and set the LD_LIBRARY_PATH
> Andreas
> Am 08.10.2013 14:36, schrieb BLANDENIER Lucien:
>> Thank you andrea for your answer!
>> You convinced me! Just one additional question. On Linux, if I upgrade to qgis2, is to possible to go back to 1.8? And how? I have some projects and maps I don't want to upgrade. I've looked on internet how to go back to a previous version but I didn't found something.
>> Lucien
>> ps : thank you to all the developers who are working on this project !!!
>> ________________________________________
>> De : qgis-user-bounces at lists.osgeo.org [qgis-user-bounces at lists.osgeo.org] de la part de Andreas Neumann [a.neumann at carto.net]
>> Envoyé : mardi 8 octobre 2013 16:22
>> À : qgis-user at lists.osgeo.org
>> Objet : Re: [Qgis-user] QGIS 2.0.1
>> Hi Lucien,
>> You should definitely use the 2.0x releases. It is in most respects
>> better than the 1.x releases.
>> Here is a list of most of the new features:
>> http://changelog.linfiniti.com/version/1/ (don't be fooled about the
>> URL, it really describes the new features of version 2)
>> - Especially the new Processing toolbox and graphical modeler is new and
>> exciting.
>> If you are on Windows, you should definitely go with the 64bit version,
>> which is new as well.
>> As with all new features there are also bugs. If you rely on external
>> software like GRASS and SAGA there may still be some integration issues
>> we are working on. There will be updated installers that should fix
>> these issues.
>> As to compatibility: it mostly is, but there are some issues when going
>> from old to new symbology and from old to new labeling.
>> Andreas
>> Am 08.10.2013 14:05, schrieb BLANDENIER Lucien:
>>> Dear all,
>>> I've seen that the QGIS 2.0.1 is now available and looks promising! Did someone already has some feedback ? Is it stable?
>>> I saw that the map manager changed, as well as other features. Is it compatible with previous versions?
>>> Regards
>>> Lucien
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
