[Qgis-user] importing .dwg files in qgis 2.0 on ubuntu 12.04.02
Guus van den Berg
gtcvandenberg at gmail.com
Tue Oct 8 08:08:33 PDT 2013
Thanks Arlindo! The links did'nt help in my case. However I found
another solution which I would like to share here: _VariCad_ _Viewer_.
You can find it in the Ubuntu Softwarecenter. According to the
information Sofwarecenter provides it's free of charge (though not
freeware, as is Draftsight) and it's designed for 64bit Ubuntu. It seems
to open and convert dwg to dxf just right.
Cheers,
Guus.
op 08-10-13 15:36, Arlindo Fabrício Corrêia schreef:
> I use the Draftisight in Ubuntu 13.04 64 bit, no problem.
> See this link -->
> http://geoparalinux.wordpress.com/2012/04/27/faca-o-draftsight-32-bits-rodar-no-ubuntu-12-04-64-bits/
> or
> http://blogs.bu.edu/mhirsch/2012/12/draftsight-cad-software-on-ubuntu-12-10-64-bit/
> http://www.vivaolinux.com.br/topico/Perguntas-nao-tao-frequentes/Instalando-o-DraftSight-32-e-64bits-no-Ubuntu-Linux
> http://askubuntu.com/questions/39647/how-do-i-install-draftsight-cad
> 2013/10/8 Guus van den Berg <gtcvandenberg at gmail.com
> <mailto:gtcvandenberg at gmail.com>>
> Hi,
> Before a while I was able to open .dwg-files in Draftsight. This
> program however still isn't available for 64bit ubuntu. The
> workarounds I used before (for example:
> http://linuxaideddesign.blogspot.nl/2012/03/draftsight-and-ubuntu-1204-lts-64bit.html)
> all seem to clash on installing. Does anyone have a solution other
> than DraftSight? Or am I missing a recent workaround? You'd be
> helping me out seriously!
> Cheers,
> Guus van den Berg
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> Engenheiro Agrônomo - (45) 9974-3239
> Doutorando em Agronomia - UNIOESTE - Mal. Cdo. Rondon/PR
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131008/97417053/attachment.html>
