[Qgis-user] No ECW support in QGis 2.0
Alexandre Neto senhor.neto at gmail.com
Mon Oct 14 04:58:07 PDT 2013
Hello Santiago,
Please also note that, by default, the 64bit installer will create a
OSGeo4W64 folder instead od the usual OSGeo4W one (you can choose a
different name tho), so any needed "hack" that you find should be done
there.
Best regards,
Alexandre Neto
On Mon, Oct 14, 2013 at 12:51 PM, Nathan Woodrow <madmanwoo at gmail.com>wrote:
> 64bit QGIS (if you used the 64bit installer) on Windows supports ECW out
> of the box. You shouldn't need to install anything extra.  The 32bit
> install currently doesn't support it and you will have to the use the
> method in the in the blog post.
> - Nathan
> On Mon, Oct 14, 2013 at 9:49 PM, Santiago Moreno <santiago.moreno at upm.es>wrote:
>> Hi,
>> I have tried to follow direccions in http://www.faunalia.com/**
>> content/adding-ecw-support-**quantum-gis<http://www.faunalia.com/content/adding-ecw-support-quantum-gis>in order to use ECW files in Q-GIS. I have Quantum GIS 2.0 (windows 7, 64)
>> with the osgeo4w but I do not have the folders c:\OSGeo4W\bin and
>> c:\OSGeo4W\bin\gdalplugins\1.9 where I could copy the files libecwj2.dll
>> and gdal_ECW_JP2ECW.dll as suggested. Instead I have C:\Program Files\QGIS
>> Dufour\bin\gdalplugins. Please, where shoud I copy these two dll files.
>> Thank you
>> Santiago Moreno
>> ______________________________**_________________
>> Qgis-user mailing list
>> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131014/152a99f0/attachment.html>
