[Qgis-user] No ECW support in QGis 2.0
Santiago Moreno santiago.moreno at upm.es
Mon Oct 14 05:57:04 PDT 2013
Thank you Nathan and Alexandre. When installing 64 bit QGIS the
OSGeo4W icon was installed on the desktop, however neither a OSGeo4W
nor a OSGeo4W64 forder was created. When trying to load my ECW file I
am getting the message: "xxx.ecw is not an accepted raster data source".
Regards,
Santiago
At 13:58 14/10/2013, Alexandre Neto wrote:
>Hello Santiago,
>Please also note that, by default, the 64bit installer will create a
>OSGeo4W64 folder instead od the usual OSGeo4W one (you can choose a
>different name tho), so any needed "hack" that you find should be done there.
>Best regards,
>Alexandre Neto
>On Mon, Oct 14, 2013 at 12:51 PM, Nathan Woodrow
><<mailto:madmanwoo at gmail.com>madmanwoo at gmail.com> wrote:
>64bit QGIS (if you used the 64bit installer) on Windows supports ECW
>out of the box. You shouldn't need to install anything extra.  The
>32bit install currently doesn't support it and you will have to the
>use the method in the in the blog post.
>- Nathan
>On Mon, Oct 14, 2013 at 9:49 PM, Santiago Moreno
><<mailto:santiago.moreno at upm.es>santiago.moreno at upm.es> wrote:
>Hi,
>I have tried to follow direccions in
><http://www.faunalia.com/content/adding-ecw-support-quantum-gis>http://www.faunalia.com/content/adding-ecw-support-quantum-gis
>in order to use ECW files in Q-GIS. I have Quantum GIS 2.0 (windows
>7, 64) with the osgeo4w but I do not have the folders c:\OSGeo4W\bin
>and c:\OSGeo4W\bin\gdalplugins\1.9 where I could copy the files
>libecwj2.dll and gdal_ECW_JP2ECW.dll as suggested. Instead I have
>C:\Program Files\QGIS Dufour\bin\gdalplugins. Please, where shoud I
>copy these two dll files.
>Thank you
>Santiago Moreno
>_______________________________________________
>Qgis-user mailing list
><mailto:Qgis-user at lists.osgeo.org>Qgis-user at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131014/97e8561f/attachment.html>
