[Qgis-user] QGIS Harlem Shake
    KLGan
    1klgan at gmail.com
    Mon Oct 14 20:43:49 PDT 2013
Hi Johan,
I tried log in and out, the shaking did not stop.
Any more ideas?
Thanks
KLGan
On Oct 13, 2013 6:21 PM, "Johan Nilsson" <joni8135 at gmail.com> wrote:
> Did you try to log out Unity 3D and in to Unity 2D? I had some strange
> issues with 3D, that get solved by running 2D a while and then log in to 3D
> again...Othervise 2D may word. You do not need to reboot, just log out and
> in again.
> 2013/10/13 KLGan <1klgan at gmail.com>
>> I use this command in terminal to update Ubuntu.
>> sudo add-apt-repository ppa:ubuntu-x-swat/x-updates
>> After restart, I installed QGIS. Guess what, same problem still there,
>> Harlem shake!...
>> I'm forced to use QGIS in Windows now....  :-(
>> What else can be done to stop the shaking.
>> Thanks
>> KLGan
>> On Oct 9, 2013 1:36 AM, "Alex Mandel" <tech_dev at wildintellect.com> wrote:
>>> On 10/08/2013 09:12 AM, Goyo wrote:
>>> > 2013/10/8 KLGan <1klgan at gmail.com>:
>>> >> Hi Johan & Alex,
>>> >> Thanks for reply.
>>> >> Here is the hardware spec and software:-
>>> >> Ubuntu 13.04
>>> >> Memory 2.0Gib
>>> >> Processor: Genuine Intel® CPU T2080 @ 1.73GHz × 2
>>> >> Graphics: Intel® 945GM x86/MMX/SSE2
>>> >> OS Type: 32-bit
>>> > ¿Might this be a window manager issue? I remember problems with QGIS
>>> > and window management in ubuntu (unity) before, like QGIS going to
>>> > another virtual desktop on startup.
>>> > Goyo
>>> I actually think in this case it's the Intel graphics drivers. I've
>>> talked with some other who have had similar issues but only with the
>>> splash screen (for QGIS and other graphics heavy programs).
>>> So I think the best thing to pursue is checking Ubuntu bug reports for
>>> Intel graphics driver fixes for the 945GM. There may actually be grub
>>> based flags to help.
>>> Some ideas:
>>> http://askubuntu.com/questions/101028/unity-3d-not-supported-intel-945gm-graphics-card
>>> https://bugs.launchpad.net/ubuntu/+source/linux/+bug/543265
>>> Changing window manager might work, or just logging in with Unity 2D
>>> might even work.
>>> I know on my 12.04 machine I have to run kernel 3.5 or newer for my
>>> Intel HD4000 to work right.
>>> Thanks,
>>> Alex
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131015/37abc441/attachment.html>
