[Qgis-user] QGIS Harlem Shake
Alex Mandel tech_dev at wildintellect.com
Mon Oct 14 20:57:03 PDT 2013
When you log out, you have pick to login to Unity 2D. Other options are
to trying installing XFCE, KDE or another window manager. Another way to
test, try booting OSGeoLive from a usb or DVD to see if it has the same
problem.
Thanks,
Alex
On 10/14/2013 08:43 PM, KLGan wrote:
> Hi Johan,
> I tried log in and out, the shaking did not stop.
> Any more ideas?
> Thanks
> KLGan
> On Oct 13, 2013 6:21 PM, "Johan Nilsson" <joni8135 at gmail.com> wrote:
>> Did you try to log out Unity 3D and in to Unity 2D? I had some strange
>> issues with 3D, that get solved by running 2D a while and then log in to 3D
>> again...Othervise 2D may word. You do not need to reboot, just log out and
>> in again.
>> 2013/10/13 KLGan <1klgan at gmail.com>
>>> I use this command in terminal to update Ubuntu.
>>> sudo add-apt-repository ppa:ubuntu-x-swat/x-updates
>>> After restart, I installed QGIS. Guess what, same problem still there,
>>> Harlem shake!...
>>> I'm forced to use QGIS in Windows now....  :-(
>>> What else can be done to stop the shaking.
>>> Thanks
>>> KLGan
>>> On Oct 9, 2013 1:36 AM, "Alex Mandel" <tech_dev at wildintellect.com> wrote:
>>>> On 10/08/2013 09:12 AM, Goyo wrote:
>>>>> 2013/10/8 KLGan <1klgan at gmail.com>:
>>>>>> Hi Johan & Alex,
>>>>>> Thanks for reply.
>>>>>> Here is the hardware spec and software:-
>>>>>> Ubuntu 13.04
>>>>>> Memory 2.0Gib
>>>>>> Processor: Genuine Intel® CPU T2080 @ 1.73GHz × 2
>>>>>> Graphics: Intel® 945GM x86/MMX/SSE2
>>>>>> OS Type: 32-bit
>>>>> ¿Might this be a window manager issue? I remember problems with QGIS
>>>>> and window management in ubuntu (unity) before, like QGIS going to
>>>>> another virtual desktop on startup.
>>>>> Goyo
>>>> I actually think in this case it's the Intel graphics drivers. I've
>>>> talked with some other who have had similar issues but only with the
>>>> splash screen (for QGIS and other graphics heavy programs).
>>>> So I think the best thing to pursue is checking Ubuntu bug reports for
>>>> Intel graphics driver fixes for the 945GM. There may actually be grub
>>>> based flags to help.
>>>> Some ideas:
>>>> http://askubuntu.com/questions/101028/unity-3d-not-supported-intel-945gm-graphics-card
>>>> https://bugs.launchpad.net/ubuntu/+source/linux/+bug/543265
>>>> Changing window manager might work, or just logging in with Unity 2D
>>>> might even work.
>>>> I know on my 12.04 machine I have to run kernel 3.5 or newer for my
>>>> Intel HD4000 to work right.
>>>> Thanks,
>>>> Alex
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
