[Qgis-user] Topological editing of two vector layers
Lene Fischer lfi at life.ku.dk
Mon Oct 14 22:43:02 PDT 2013
Hello Deon
You can use the function Avoid Intersection while digitizing.
In this way you avoid overlap - but not gaps.
Read more about this issue in the usermanual
http://qgis.org/en/docs/gentle_gis_introduction/06_topology.html?highlight=snap
http://qgis.org/en/docs/user_manual/working_with_vector/editing_geometry_attributes.html?highlight=snap
Regards
Lene Fischer
Fra: qgis-user-bounces at lists.osgeo.org [qgis-user-bounces at lists.osgeo.org] på vegne af Pretorius Deon - Lieutenant Colonel [PretoriusDeon at saps.gov.za]
Sendt: 15. oktober 2013 06:55
Til: 'qgis-user at lists.osgeo.org'
Emne: [Qgis-user] Topological editing of two vector layers
Hi, Iam new to QGIS. I have two boundary vector  layers, the one exist of polygons of all the provinces and the other of all the districts.  The district boundaries must be aligned with the provincial boundaries.  Since there is so much errors that needs alignment and rectification  I was wondering if there isn’t an easier way as to snap to the boundaries without to drag each vertex which is very time consuming.  Is there perhaps a way where the whole identified segments/vertex of the districts can be aligned easier to the provincial boundaries.
Regards
Deon Pretorius
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131015/f4538dea/attachment.html>
