[Qgis-user] Topological editing of two vector layers
    Carlos Cerdán
    sig.upagu at gmail.com
    Tue Oct 15 06:55:10 PDT 2013
... or you can disolve your districts to obtain new provinces and leave the
old layer
Good luck
Carlos Cerdán
2013/10/15 Lene Fischer <lfi at life.ku.dk>
>  Hello Deon
> You can use the function Avoid Intersection while digitizing.
> In this way you avoid overlap - but not gaps.
> Read more about this issue in the usermanual
> http://qgis.org/en/docs/gentle_gis_introduction/06_topology.html?highlight=snap
> http://qgis.org/en/docs/user_manual/working_with_vector/editing_geometry_attributes.html?highlight=snap
>  Regards
> Lene Fischer
> *Fra:* qgis-user-bounces at lists.osgeo.org [
> qgis-user-bounces at lists.osgeo.org] på vegne af Pretorius Deon -
> Lieutenant Colonel [PretoriusDeon at saps.gov.za]
> *Sendt:* 15. oktober 2013 06:55
> *Til:* 'qgis-user at lists.osgeo.org'
> *Emne:* [Qgis-user] Topological editing of two vector layers
>   Hi, Iam new to QGIS. I have two boundary vector  layers, the one exist
> of polygons of all the provinces and the other of all the districts.  The
> district boundaries must be aligned with the provincial boundaries.  Since
> there is so much errors that needs alignment and rectification  I was
> wondering if there isn’t an easier way as to snap to the boundaries without
> to drag each vertex which is very time consuming.  Is there perhaps a way
> where the whole identified segments/vertex of the districts can be aligned
> easier to the provincial boundaries.
> Regards
> Deon Pretorius
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131015/268825cb/attachment.html>
