[Qgis-user] QGIS 2.0 Postgres Connection Problem?
Andreas Neumann
a.neumann at carto.net
Tue Oct 15 07:32:10 PDT 2013
The service configuration is optional. If you did not specify a
PostgreSQL service you should leave the service field empty.
Services are a good way to keep PostgreSQL connections independent of
IP-addresses and computer names. You define a service and can exchange
the datatabase server underneath that service (running on a different
ip/name) but under the same service name.
I use PG servcices for all of my QGIS projects because I need to move
them around on different servers.
See http://www.postgresql.org/docs/current/static/libpq-pgservice.html
Andreas
Am 15.10.2013 15:44, schrieb Gibbons, John:
> I was able to connect to a Postgres database in v1.9, but am getting an error in version 2.0.
> When I submit the connection details I get ERROR: service file "/etc/pg_service.conf" not found
> I can confirm that this file does not seem to exist on my PC, I didn't have a problem with this in 1.9.
> Has anyone seen this and managed to get around the problem?
> DISCLAIMER: The information contained in this communication/message from John.Gibbons at salford.gov.uk sent on Tue Oct 15 14:44:33 2013 is confidential and may be legally privileged. It is intended solely for the addressee(s) qgis-user at lists.osgeo.org
> Access to this message by anyone else is unauthorised. If you are not the intended recipient, any disclosure, copying, or distribution of the message, or any action or omission taken by you in reliance on it, is prohibited and may be unlawful.
> As a public body, Salford City Council may be required to disclose this email [or any response to it] under the Freedom of Information Act 2000, unless the information in it is covered by one of the exemptions in the Act.
> Please immediately contact the sender, John.Gibbons at salford.gov.uk if you have received this message in error.
> For the full disclaimer please access http://www.salford.gov.uk/e-mail. Thank you.
> Qgis-user mailing list
