[Qgis-user] GRASS integration in QGIS 2
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Wed Oct 16 06:56:21 PDT 2013
Thanks Steven, unfortunately the Network version isn't an option for me;
has to be the stand-alone one.
Does anyone know if this is being addressed in the new build(s) that are
being created to resolve the other issues?
Jonathan
On 16 October 2013 14:51, Steven Horner <steven at stevenhorner.com> wrote:
> I had exactly the same problem with the standalone installer for Windows
> 64bit. I had other problems with the OSgeo4W installer but I have now got
> the grass commands working in the processing toolbox after installing using
> the OSGeo4W Network 64bit installer.
> The dev version didn't work for me either in the Network installer, but
> that was a week ago.
> On 16 Oct 2013 14:43, "Jonathan Moules" <
> jonathanmoules at warwickshire.gov.uk> wrote:
>> Hi List,
>> I'm using the 64bit Windows stand-alone install of QGIS 2.
>> As best I can tell this includes GRASS (it's listed in the plugins as
>> enabled, and there's a "Pluging -> GRASS" menu set.
>> However, when I try and run the r.water.outlet tool (or any other GRASS
>> tool) from the Processing Toolbox I get an error:
>> "Missing dependency.This algorithm cannot be run :-(
>> This algorithm requires GRASS to be run.Unfortunately, it seems that
>> GRASS is not installed in your system, or it is not correctly configured to
>> be used from QGIS
>> Click here<http://docs.qgis.org/2.0/html/en/docs/user_manual/processing/3rdParty.html>to know more about how to install and configure GRASS to be used with QGIS"
>> What's going on? How do I get these to work?
>> Thanks,
>> Jonathan
>> This transmission is intended for the named addressee(s) only and may
>> contain sensitive or protectively marked material up to RESTRICTED and
>> should be handled accordingly. Unless you are the named addressee (or
>> authorised to receive it for the addressee) you may not copy or use it, or
>> disclose it to anyone else. If you have received this transmission in error
>> please notify the sender immediately. All email traffic sent to or from us,
>> including without limitation all GCSX traffic, may be subject to recording
>> and/or monitoring in accordance with relevant legislation.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131016/9a041237/attachment.html>
