[Qgis-user] GRASS integration in QGIS 2
Steven Horner
steven at stevenhorner.com
Wed Oct 16 06:51:48 PDT 2013
I had exactly the same problem with the standalone installer for Windows
64bit. I had other problems with the OSgeo4W installer but I have now got
the grass commands working in the processing toolbox after installing using
the OSGeo4W Network 64bit installer.
The dev version didn't work for me either in the Network installer, but
that was a week ago.
On 16 Oct 2013 14:43, "Jonathan Moules" <jonathanmoules at warwickshire.gov.uk>
wrote:
> Hi List,
> I'm using the 64bit Windows stand-alone install of QGIS 2.
> As best I can tell this includes GRASS (it's listed in the plugins as
> enabled, and there's a "Pluging -> GRASS" menu set.
> However, when I try and run the r.water.outlet tool (or any other GRASS
> tool) from the Processing Toolbox I get an error:
> "Missing dependency.This algorithm cannot be run :-(
> This algorithm requires GRASS to be run.Unfortunately, it seems that GRASS
> is not installed in your system, or it is not correctly configured to be
> used from QGIS
> Click here<http://docs.qgis.org/2.0/html/en/docs/user_manual/processing/3rdParty.html>to know more about how to install and configure GRASS to be used with QGIS"
> What's going on? How do I get these to work?
> Thanks,
> Jonathan
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131016/a919be0b/attachment.html>
