[Qgis-user] GRASS integration in QGIS 2
    Jonathan Moules
    jonathanmoules at warwickshire.gov.uk
    Wed Oct 16 06:42:41 PDT 2013
Hi List,
  I'm using the 64bit Windows stand-alone install of QGIS 2.
As best I can tell this includes GRASS (it's listed in the plugins as
enabled, and there's a "Pluging -> GRASS" menu set.
However, when I try and run the r.water.outlet tool (or any other GRASS
tool) from the Processing Toolbox I get an error:
"Missing dependency.This algorithm cannot be run :-(
This algorithm requires GRASS to be run.Unfortunately, it seems that GRASS
is not installed in your system, or it is not correctly configured to be
used from QGIS
Click here<http://docs.qgis.org/2.0/html/en/docs/user_manual/processing/3rdParty.html>to
know more about how to install and configure GRASS to be used with
QGIS"
What's going on? How do I get these to work?
Thanks,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131016/4207a79e/attachment.html>
