[Qgis-user] "on the fly" reprojection options in 2.0
Radim Blazek radim.blazek at gmail.com
Wed Oct 16 13:37:07 PDT 2013
On Tue, Oct 15, 2013 at 5:06 PM, Jonathan Moules
<jonathanmoules at warwickshire.gov.uk> wrote:
> Hi Ramon,
> Thanks for the clarification.
> But given that, shouldn't they be radio buttons, not checkboxes? They
> certainly sound mutually exclusive.
Yes, I fixed that in master.
Radim
> Jonathan
> On 15 October 2013 15:00, Ramon AndiƱach <custard at westnet.com.au> wrote:
>> That got me too.
>> > On 15 Oct 2013, at 21:26, Jonathan Moules
>> > Hi List,
>> >   Maybe it's just me, but in 2.0 under Settings -> Options -> CRS I have
>> > two options:
>> > "Automatically enable 'on the fly' reprojection if layers have different
>> > CRS"
>> This is "don't turn on OTF until you need it."
>> So OTF starts off, but will turn on when you load something in a different
>> CRS.
>> > and
>> > "Enable 'on the fly' reprojection by default"
>> This is "just turn OTF on and be done with it already".
>> So OTF starts on and stays on.
>> > My question - what is the difference between these two? They sound like
>> > different phrasings of the same thing.
>> So slightly different rules on how you want OTF to behave.
>> It might be that you almost exclusively work in one CRS, but occasionally
>> use something in another CRS, in which case the first option is good for
>> you.
>> Or you might be somewhere that you will use 2 or three different CRS each
>> day so the second is just simpler.
>> Also, as good as QGIS's OTF is (and I think it's fantastic) there will
>> always be a cost to using it, so if you're a speed freak or have big data
>> you probably don't want OTF on unless you need it.
>> I'm sure one of the others will step in if I've got this all wrong.
>> -ramon.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
