[Qgis-user] Saving layers
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Thu Oct 17 08:07:12 PDT 2013
Hi Lene,
No, it's not the project I want to save (that's akin to a ArcMap mxd file),
it is individual layers or layer-groups (akin to a ArcMap lyr file).
Thanks though,
Jonathan
On 17 October 2013 15:58, Lene Fischer <lfi at life.ku.dk> wrote:
> Hello Jonathan,
> Do you think about saving as a project?
> When you save the project - it include path, CRS, colour/style, label,
> printcomposer - everything.
> http://qgis.org/en/docs/user_manual/introduction/qgis_configuration.html#project-properties
> Regards
> Lene Fischer
> *Fra:* qgis-user-bounces at lists.osgeo.org [
> qgis-user-bounces at lists.osgeo.org] på vegne af Jonathan Moules [
> jonathanmoules at warwickshire.gov.uk]
> *Sendt:* 17. oktober 2013 15:36
> *Til:* qgis-user at lists.osgeo.org
> *Emne:* [Qgis-user] Saving layers
> Hi List,
> I'm wondering if QGIS can save links to layers as stand alone files,
> similar to how ArcMap does it.
> I know I can save the style, but I want to save everything about the layer
> including data location etc in a file which I can then share with others.
> The style only saves the style.
> I can't seem to find such a function - is there one?
> Thanks,
> Jonathan
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131017/c15bf807/attachment.html>
