[Qgis-user] Saving layers
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Thu Oct 17 10:53:04 PDT 2013
Jonathan -
* Open the shape file as a layer in QGIS and style this layer.
* When you haved styled the layer, use the "Layer Properties" ->
"Style" -> "Save Style" button on the layer
* Choose "QGIS Layer Style File" and create a qml style file.
* Save the style file to the same directory as your shape file is
placed in - and with the same name prefix (Meaning: If the shape
file is called c:\mydir\myshape.shp the qml file must be named
c:\mydir\myshape.qml)
From now on, every time you open the shape file as a layer in QGIS , it
will be styled according to the style parameters in the qml file.
Regards
Bo Victor Thomsen
Aestas-GIS
Denmark
Den 17-10-2013 17:07, Jonathan Moules skrev:
> Hi Lene,
> No, it's not the project I want to save (that's akin to a ArcMap mxd
> file), it is individual layers or layer-groups (akin to a ArcMap lyr
> file).
> Thanks though,
> Jonathan
> On 17 October 2013 15:58, Lene Fischer <lfi at life.ku.dk
> <mailto:lfi at life.ku.dk>> wrote:
> Hello Jonathan,
> Do you think about saving as a project?
> When you save the project - it include path, CRS, colour/style,
> label, printcomposer - everything.
> http://qgis.org/en/docs/user_manual/introduction/qgis_configuration.html#project-properties
> Regards
> Lene Fischer
> *Fra:* qgis-user-bounces at lists.osgeo.org
> <mailto:qgis-user-bounces at lists.osgeo.org>
> [qgis-user-bounces at lists.osgeo.org
> <mailto:qgis-user-bounces at lists.osgeo.org>] på vegne af Jonathan
> Moules [jonathanmoules at warwickshire.gov.uk
> <mailto:jonathanmoules at warwickshire.gov.uk>]
> *Sendt:* 17. oktober 2013 15:36
> *Til:* qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
> *Emne:* [Qgis-user] Saving layers
> Hi List,
> I'm wondering if QGIS can save links to layers as stand alone
> files, similar to how ArcMap does it.
> I know I can save the style, but I want to save everything about
> the layer including data location etc in a file which I can then
> share with others. The style only saves the style.
> I can't seem to find such a function - is there one?
> Thanks,
> Jonathan
> This transmission is intended for the named addressee(s) only and
> may contain sensitive or protectively marked material up to
> RESTRICTED and should be handled accordingly. Unless you are the
> named addressee (or authorised to receive it for the addressee)
> you may not copy or use it, or disclose it to anyone else. If you
> have received this transmission in error please notify the sender
> immediately. All email traffic sent to or from us, including
> without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use
> it, or disclose it to anyone else. If you have received this
> transmission in error please notify the sender immediately. All email
> traffic sent to or from us, including without limitation all GCSX
> traffic, may be subject to recording and/or monitoring in accordance
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131017/39786208/attachment.html>
