[Qgis-user] Tryinh to use a TMS minidriver -> RasterIO error
Jean-Roc Morreale jr.morreale at enoreth.net
Fri Oct 18 06:55:39 PDT 2013
I'm trying to use a TMS dataset in QGIS 2.0 using an xml minidriver but
when I load it into a project, the log is showing this error :
RasterIO error: D:/tiles/example.xml, band 4: IReadBlock failed at X
offset 9, Y offset 18
Tiles were made using gdal2tiles, openlayers is able to display it.
Here are all the files (xml, gdalinfo, tiles) : http://goo.gl/o56OxE
Could someone tell me if it is a bug or a mistake in the xml files ?
Regards,
Jean-Roc
