[Qgis-user] Time Manager Fail
Anita Graser
anitagraser at gmx.at
Fri Oct 18 11:22:15 PDT 2013
Please use the Time Manager bug tracker:
https://github.com/anitagraser/TimeManager/issues
I'm working with Time Manager for QGIS 2.0 on Win 7 and animations
definitely work but it's well possible that there are some issues when
saving the project.
If possible, please share data to reproduce the problems.
Best wishes,
Anita
Am 18.10.2013, 18:31 Uhr, schrieb . <digitalmaps at cox.net>:
> Time Manager doesn't work with either 32 bit or 64 bit version on WIn 7
> 64 bit.
> Time Manager layers don't save. When reloading project, layer listing in
> Time Manager is blank, empty.
> Also, there is an issue with data points not being visible if their
> beginning time index isn't the same. Layers with a later time index are
> not displayed. This can be corrected by fast forwarding to the time
> index where all are visible, then forcing a layer reload in Time Manager
> settings. After that all layers display properly.
> The animation works until you save the project, exit, then restart.
> Then, no layers in Time Manager.
> This is with a blank, new project file.
> I tried this with three dozen layers and it failed. I tried this with a
> ... deleted QGIS 1.8 and scrubbed all config files.
> ... installed 32 bit and alternately 64 bit QGIS 2.0.
