[Qgis-user] HTML tags in label expresion on QGIS 2.0.1
Paulius Litvinas
paulius at infoera.lt
Mon Oct 21 23:22:39 PDT 2013
Hello list,
I tried to use HTML bold tag <b></b> for a part of label text in label
expression.
HTML tags are properly interpreted and rendered on "Expression based label"
dialog at Output preview, but unfortunately not the same on the map.
You can see in the image below - red and green areas.
http://img42.com/Hd4Zp
Maybe there is some kind of setting to enable this on map render? (I
couldn't find) Or this is a bug?
As I remember this used to work in 1.x versions.
Sincerely,
Paul
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131022/89411066/attachment.html>
