[Qgis-user] HTML tags in label expresion on QGIS 2.0.1
Nathan Woodrow
madmanwoo at gmail.com
Mon Oct 21 23:39:08 PDT 2013
Hey,
HTML based labels aren't supported yet. What you see in the dialog is a
render preview using a QLabel which can handle HTML. I need to change that
to just use plain text rather then rich text.
It was never supported in any older versions.
- Nathan
On Tue, Oct 22, 2013 at 4:22 PM, Paulius Litvinas <paulius at infoera.lt>wrote:
> Hello list,****
> I tried to use HTML bold tag <b></b> for a part of label text in label
> expression.****
> HTML tags are properly interpreted and rendered on „Expression based
> label“ dialog at Output preview, but unfortunately not the same on the map.
> You can see in the image below – red and green areas.****
> http://img42.com/Hd4Zp****
> Maybe there is some kind of setting to enable this on map render? (I
> couldn‘t find) Or this is a bug?****
> As I remember this used to work in 1.x versions.****
> Sincerely,****
> Paul****
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131022/f3ea63eb/attachment.html>
