[Qgis-user] db-manager (temporary tables)
Andreas Neumann
a.neumann at carto.net
Tue Oct 22 05:00:52 PDT 2013
What do you mean by "temp tables"?
There are no "temp tables" in a database. Either it is a table, a view
or a table. All of these can already be opened with DB manager.
Andreas
Am 22.10.2013 13:57, schrieb António M. Rodrigues:
> The thing is I have some custom functions which output temp tables. And it
> would be useful to be able to explore these tables in db-manager.
> I guess it shouldn't be too difficult to tweak dbmanager.
> I was looking at the source code for but unfortunately my knowledge of
> pyqgis is not quite there (maybe one day... :--) ).
> António
> 2013/10/22 Andreas Neumann <a.neumann at carto.net>
>> Hi,
>> You can load query results in db-manager.
>> Just create a query in db-manager, select the primary key column and the
>> geometry column and load it.
>> Works fine for me.
>> Andreas
>> Am 22.10.2013 13:42, schrieb António M. Rodrigues:
>>> Hi,
>>> Is there a way to access temporary tables through db-manager?
>>> From what I get, this is only possible through layer->add postgis layer
>>> (also not available in the browser panel).
>>> Thanks,
>>> António
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
