[Qgis-user] Problem with WMS 1.1.1 data providers in QGIS 2.0.1
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Tue Oct 22 07:12:51 PDT 2013
> For my mind it should be possible to configure QGIS WMS to run in a safe
> mode and use only those parameters which belong to WMS standard.
+1
Thinking about it, what about a dialog where it's possible to configure
what a standard WMS request contains?
Ignore the fact it looks suspiciously like Excel, but imagine a QGIS dialog
that let you put pieces together like this:
[image: Inline images 2]
Where % are predefined QGIS variables. Use a "+" and "-" button to
add/remove rows (and thus parameters) to the table.
Could work for WFS and WCS too.
Create various different "profiles" and distribute those as standard. Easy
to use for both lay-users (pre-configured profiles that are specification
compliant), and technical users.
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131022/a11b9276/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131022/a11b9276/attachment.png>
