[Qgis-user] How to make use of python variables in Qgis filter expression
Mathieu Bossaert (CEN L-R) sig at cenlr.org
Thu Oct 24 01:04:46 PDT 2013
Hello everyone,
I found ! Looking around a solution to my problem, I understand that python would be the solution .
Thanks to the QGis documentation and to those 3 resources :
- http://nathanw.net/2012/11/10/user-defined-expression-functions-for-qgis/
- http://www.3liz.com/blog/rldhont/index.php?post/2012/11/06/Op%C3%A9rateurs-spatiaux-dans-les-expressions-de-QGIS
- http://gis.stackexchange.com/questions/28625/how-to-create-a-polygon-based-on-view-extent-in-qgis-1-8
So I created a python script ( userfunctions.py ), which contains a function called current_canvas_extent , which returns a Polygon representing the current influence of the window.
[code]
from qgis.utils import qgsfunction
from qgis.utils import iface
from qgis.core import QGis
@qgsfunction(0, "Python")
def current_canvas_extent(values, feature, parent):
retourne l etendue courante de la carte
##extend = QgsGeometry.fromRect( iface.mapCanvas().extent() )
##extend = iface.mapCanvas().extent().toString()
extend = iface.mapCanvas().extent().asWktPolygon()
return extend
[/code]
QGis call the script on start (add the option " - code path \ to \ userfunctions.py " )
So I now have access to this "variable" inside the expression editor.
And I can ask QGis restrict the list to the objects intersecting the current canvas.
[code]
intersects ($ geometry , geomFromWKT ($ current_canvas_extent ) )
[/code]
Thanks a lot for this great software you give us!
Mathieu BOSSAERT
Responsable du système d'information
Membre de la Fédération des Conservatoires d'espaces naturels www.reseau-cen.org
----- Mail original -----
De: "Mathieu Bossaert (CEN L-R)" <mathieu.bossaert at cenlr.org>
À: qgis-user at lists.osgeo.org
Envoyé: Mardi 1 Octobre 2013 11:26:55
Objet: How to make use of python variables in Qgis filter expression
Good morning,
thanks to the new Qgis, I can make a really pratical interface to my postgis database. I want to make use of relationnal value in the editing form.
The table I use to populate the list is a spatial table.
I would like to restrict the list of available values in the form to the objects within the current extent of my map.
I found an example wich is ok but I would like to make use of a variable instead of a fixed extend (GeomFromWKT()).
The example I tried is here : http://www.3liz.com/blog/rldhont/index.php?post/2012/11/06/Spatial-operators-in-QGIS-expression
Thanks a lot,
Mathieu
Mathieu BOSSAERT
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131024/de6694e7/attachment.html>
