[Qgis-user] Is there a limit for the nb. of vector layers in a QGIS Project ???
Marcel Stadelmann
marcel.stadelmann at gmx.net
Sun Oct 27 00:02:05 PDT 2013
Hi Paulo,
I observed a similar problem. I can't load more then 32 layers in a project without problems. However I haven't updated to the latest QGIS version. Maybe it's a Mac Problem. I use Mac OSX 10.8.4
regards
Marcel
Am 18.10.2013 um 02:54 schrieb Paulo Gali Macedo <pgmacedo at fc.up.pt>:
> Hi Fellows,
> Being a Rooky (beginner) in using QGIS, I would like to know if there is a limit for the number of vector layers in a QGIS Project.
> The reason for my question has to do with a problem I encountered when using QGIS in a Project.
> The project has to do with plotting several routes (vector layers) over a Google Earth + an SRMT raster layers. The Vector layers where imported from .gpx files.
> I was doing the job gradually one by one, until when I was given by QGIS the message that it didn't recognize one of the .gpx layers as a valid layer.
> To try to understand why, I had a look at the structure of the file and found no reason whatsoever for the QGIS refusal to accept it and convert it to a vector file.
> I then constructed another project, with the same base raster layers, and started to add Vector layers in the same way as before,... Starting exactly by the .gpx file I had been refused before to read... And... Boom... the file was red without any problems...!!!
> Has anybody in this list found a similar problem...???
> If so, is there any answer to avoid this limit problem...???
> On waiting for your answer, I thank you in advance.
> Best Wishes to You All
> Paulo Gali Macedo
> Paulo Gali Macedo
> Qgis-user mailing list
