[Qgis-user] FW: Using one vector layers to calculate the unemplyment rate in another vector layer
Zirneklitis
eko at lanet.lv
Mon Oct 28 23:01:53 PDT 2013
Just an idea:
1. Using the Field calculator add a new column with polygon areas for
the police district layer.
2. Create the third layer as an intersection between the Sensus
sub-place layer and the police district layer.
3. Using the Field calculator add a new column with polygon areas. Now
you have a attribute table to calculate the statistics.
Best regards,
Karlis
Pretorius Deon - Lieutenant Colonel wrote:
> I have a vector layer that exist out of about 1000 polygons of the
> different police districts. Then I have a Sensus sub-place vector layer
> with over 10 000 sub-places which indicate the number of unemployed
> citizens per polygon. The Sensus sub-place layer therefor overlaps with
> the police districts and when visualize some sub-places can make up 1%
> up to 100% of a given police district. Most of the police districts
> also contains 4 or more sub-places. The problem is I want to
> calculate the ”approximate” unemployment rate per police district by
> using the data from the Sensus sub-place layer. Is there perhaps an
> explanation on how I can determine” approximately proportionally” what
> the unemployment is per police district. I am new to QGIS and not up
> to date with programming, however any assistance would be appreciated.
